code API 510:
5.8.7.2 To minimize the risk of brittle fracture during a pressure test, the metal temperature should be maintained at least 30 °F (17 °C) above the MDMT or MAT for vessels that are more than 2 in. (5 cm) thick and 10 °F (6 °C) above
the MDMT or MAT for vessels that have a thickness of 2 in. (5 cm) or less. The test temperature need not exceed
120 °F (50 °C) unless there is information on the brittle characteristics of the vessel material indicating a higher test
temperature is needed.
Question: why temp. conversion deg. F - deg. C does not match?
