Mamacint
- Nov 28, 2001
- 6
I have a question about API 579, will pipe always fail Level 1 and 2 assessments and require a Level 3 analysis if there is a minimum thickness measurement below 2.5mm/0.1"? (Per Table 4.4)
If it's B31.3 and the supplemental loads are neglible such that you can perform a Level 1 analysis, must it still pass the tmm >= 0.1"? 4.4.2.1 d) seems to suggest this. How does this effect small D pipe especially 5S where tnom is less than 0.1" up to size 4"?
Thanks in advance for any help.
