Hello All,
I hope everyone is well and staying safe during these strange and difficult times.
Just wanted some opinions regarding some terminology used in ANNEX F of API 650 13th Edition...
The formula given to determine the Maximum Design Pressure (clause F.4.1) states that the value of 'A' for the participating area of the roof-to-shell joint is to be based on the corroded thickness.
However the term 'DLR' is then stated as the nominal weight of the roof plates i.e. the ordered/uncorroded thickness?
My understanding is that if we are using the corroded area in the formula then we should also use the corroded weight for the roof plates and not the nominal weight? Is this an error in the code?
The same query would also apply to clause F.5.1 when calculating the Required Compression Area.
Your thoughts/comments on this would be appreciated.
Thanks & Best Regards
