Legoman92
- Nov 9, 2021
- 28
Hi all,
Little bit of confusion from Figure 5.12 about what is allowed in regards to welding reinforcing bottom plate and the other bottom plates. Section D shows a bevelled Reinforcing bottom plate with full pen butt weld with 32mm overlap (which appears to be around the shell interface, but shows a fillet weld in section A. Do I need to provide a bevelled full penetration weld around the whole reinforcing plate/bottom plate connection? Is it acceptable to just do a regular full penetration weld between the two (see proposed detail which is taken from the flush nozzle connection)? Seems a bit ambiguous to me. See attached for images
