As per API 650 CLAUSE 8.1.2.2 b
For thinner shell plate greater than 10 mm but less than 25 mm
“In the lowest shell course, two spot radiography in each vertical joints shall be taken”
Now for our tank, shell plate thickness are 10 mm,10mm,15 mm,21 mm,and 30 mm in this case we are already taking 100 % radiography of 30 mm joints ,which is lowest shell course in tank
My concern is for fulfilling “In the lowest shell course ,two spot radiography in each vertical joints shall be taken” for 21 mm shell plate requirement,shall we take two additional radiography in existing 21 mm shell which is not actual lowest clause,or ignore the clause as we are taking 100% radiography of our 30 mm which is actual lowest shell course of tank,
Please share your expert opinions
