bryansonnier
Our company manufactures valves for the oil and gas industry. Our valves usually don't fall into the normal api valve listings as these are throttle valves 5 ksi range using dual orifice discs to control flow (think willis or baker forum or taylor throttle valve). We are gearing up for ISO certification and are formalizing our design process for future products. I would like to put a design procedure together to make sure we don't miss anything and to cross our T's and dot our I's. Is there an API design spec (is it 6A) that would be a solid basis or does AMSE Sec. 8 Div 2 work better?
Is there another design spec that would work better than those for this purpose. Currently our customers don't require one spec or the other. We are just getting into the international market and for the most part they just require a spec and aren't picky as to which one be it ISO/API/ASME etc...
Any help would be much appreciated, thank you.
(i will also post this in the asme forum as well)
