API function add mate 1
IvanaX
Computer
DE
Is it possible to add mate, without first select something with selectbyID2? Or how to make selection invisible. I don't like it, when macro is running to see what it is doing.
Yes, it is possible to add mates without selecting something with SelectByID2. You can use any selection method you want. It is not possible to add mates without selecting something by some method. It is possible to prevent graphics update during selection by setting the EnableGraphicsUpdate property of the active ModelView to False. Just don't forget to add an error handler to change back to True in the event something goes wrong.
API Help said:
ModelView::EnableGraphicsUpdate
Description
This property gets or sets whether or not to refresh the model view.
Syntax (OLE Automation)
State = ModelView.EnableGraphicsUpdate (VB Get property)
ModelView.EnableGraphicsUpdate = State (VB Set property)
State = ModelView.GetEnableGraphicsUpdate ( ) (C++ Get property)
ModelView.SetEnableGraphicsUpdate ( State ) (C++ Set property)
Output:
(VARIANT_BOOL) State
TRUE to refresh the model view, FALSE to not
Syntax (COM)
status = ModelView->get_EnableGraphicsUpdate ( &State )
status = ModelView->put_EnableGraphicsUpdate ( State )
Output:
Return:
(HRESULT) status
S_OK if successful
Remarks
This property affects whether to refresh the model view during a selection, such as Entity::Select4 or Feature::Select2.
-handleman, CSWP (The new, easy test)
yes, just what I need. Thanks
