SONVSAN1
- Apr 16, 2019
- 3
Dear all, I work in water sector and I am new to the API requirements. For a cooling water BB1 pump the custoimer wants API plan 23/62 + cooling plan M. I have seen drawings of both the plans but I do not know how both of these plan work in combination i.e. 23/62. Does this mean that I need to consider a double acting mechnaical seal ? or this can be applied to a single acting mechanical seal as well (How?). In water industry the standard seal plan is plan 11, sometimes we have double acting seal (for low inlet pressure) with thermosyphon but never encountered anything other than this.
Q: 8095 m3/hr
H: 35 m
P: 873 kW
Liquid temp.: 33°C (Max 102°C)
NPSHav: 6.84 m
Mechanical seal as per API 682 (Again the pump shaft dia is above 110 mm, API 682 should not apply here but the customer doesnt understand this)!
Thank you for your advice.
Q: 8095 m3/hr
H: 35 m
P: 873 kW
NPSHav: 6.84 m
