J. Ballard
Hello Everyone,
I've run into a failure I'm unfamiliar with on API650 tanks and could use some advice. The tank was built in 2018 to API650 App.M, 30'dia x 40'h operating at 350F. The bottom is made of 1/4" A36 and tank sits on concrete ring wall with engineered fill and pad sand inside. We recently entered the tank to change out the side mount mixer and found serious settlement issue. The engineered fill and pad sand has subsided by approximately 3". This has produced a noticeable bend in floor plates. So far the tank is not leaking but it's only a matter of time.
How do you replace the engineered fill? I've done floor replacements but those relied on support of the foundation. I'm guessing cutting out the entire floor and putting some sort of support beams attached to concrete ring wall and grillage on top?
J. Ballard BSME
J. Ballard BSME
