magmath
- Mar 21, 2007
- 12
Dear Experts.
We are constructing a 28.4 mtr dia x 17.7mtr hight CS Fixed roof storage tank. Construction is done using Jacking method oe top to bottom construction.
I would like to seek your advise on the Roundness Tolerance. As per API 650 for the size of this tank roundness tolerance is +/- 19mm. As the roundness is measured 300mm from the tank floor on the first strake, we are just checking the radius of each course at 10deg intervals.
My question is if radius of each courses checked outside the tolerance limit the is it still acceptable? as API 650 does not give any roundness tolerance for individual courses?
Thanks in advance
Thanks in advance
