UFT12
- Mar 16, 2016
- 311
I would like to post this general question, mainly to the reviewers/regulators visiting this forum.
When you get drawings showing an application area (AA) such as this...
do you consider it fine? I personally don't as the area limits are not centered between sprinklers. The problem with this, the way I understand it through many drawings I have received, is that many play this trick to skip one or two sprinklers that would normally have to be included in the AA when centered btw sprinklers.
Would you consider it OK or would you reject the design? Any thoughts appreciated.
