Apply the parameter 'Material' to all new parts
Ramon Palmera
3
ES
Hi guys,
My goal here is that in each new Part the designers make, they can add the Material info as fast as possible.
Option a) In Properties, they should find a parameter named 'Material' with multiple values: F-112, AL-6061, Black POM, ALPLANTOP.
Previously, they had to write it down in each part, either in the existing fields or in new fields.
Now I have a .txt file containing the fields "Material" and "Post-processing" to be called using the command External Properties.
Option b )The command 'Apply material', should add that info to a parameter in Properties.
Right now, I don't know in which level of the Part should I apply the Material:
I'm using CATIA V5 B19.
Thank you catiavmacro,
It just seems so obvious now, I should think more out of the box.
That might solve more issues, like the standarization of basic properties.
