SudorracMechEng
A cylindrical jackstand, with a cylinder adjustable rod inside - held to place by a pin.
I am treating this as double shear, however i am having trouble applying the appropriate fixtures.
I have applied the force on either side to only the top portion. When i apply the fixture restaint on the opposing side to - half - it yields Von mises stress of 1044 MPA... the yielding of the steel pin is 714MPA..
However, when i place fixture around entire pin, the max von mises becomes 680MPa
Two assumptions that affect my results:
1 - the pin is tight fitting, in which restraint can be fixed around whole surface - and shear is the only issue
2- "loose fitting", which means pin bending will be taken into consideration, and will yield higher stress.
I am assuming option 2.
any help guys?
any help guys?
