jmurph36
- Feb 8, 2019
- 26
I am applying an area load to an open lattice structure. But when I run the analysis and look at the transient loads, it doesn't seem to be considering the chevron bracing between columns on the lattice. I am pretty sure that, even though it is only L2x2x1/4 shapes, it still would be exposed and still needs to have wind applied to it. I have the member type set as vertical brace. When I change the member type to column, RISA applies the transient loads to the braces as well. Does anyone have any solution to this? I would like to keep the type set as vertical braces for seismic purposes.
