aegis4048
Petroleum
- Apr 23, 2024
- 36
Hi, I'm tasked with sizing a separator + heater treater for a new well. The plan is to come up with some flow predictions, and give those info to manufacturers to recommend us vessel designs. But I'm not sure how to tackle the volume prediction...
Here's the given information
1) Wellhead -> 100~200 psig normal operating P. 2-ph separator -> ~30 psig 3-phase separator -> water & oil atmospheric tanks.
2) I have offset produced oil & water rate, and sales meter gas rate. The oil and water volumes are measured from the outlet of the atmospheric tanks. The gas volume is measured at a sales meter that has combined gas from both 2-ph separator, and the 3-ph heater.
3) I have gas composition off the 2-ph separator.
4) I have API gravity of oil at the tank
5) I have access to a process simulation software (Promax) and I know how to do flash calculation
A. Given these information, how would you go about predicting liquid & flash gas volumes at 2-ph separator, heater, and the tanks?
I know that if I can get the pressurized liquid sample analysis from the 2-ph separator, and get approximate operating conditions (T & P) of the vessels, I can easily calculate flash volumes and liquid rates using the process sim software. But there's a good chance that I won't be able to obtain the pressurized liquid sample analysis from the separator.
B. If there's no liquid sample analysis, how do ppl normally size the separators and treaters?
C. If I predict the normal flowrate to be, say 100 bbl/d 50 MCF/d, how much extra room should I give it when sizing?
