chelin
- Jul 25, 2006
- 6
I'm perfoming an arc flash hazard analysis to a facility which is a data center. After giving them the results they came up with a series of requests. They want me to label each ATS's, disconnect switches and transformers. I know that NEC 110.16 and NFPA 70E 400.11 requires to label switchboards, panelboards, MCC's, meter sockets and industrial control panels... but I have not found anywhere that I need to label the requested equipment. Also, the program that I use (SKM-PTW) does not give me the option for these labels.
What should I do, reply to them that I cannot do it or should I define a bus for each ATS, disconnect and tx to get the labels?
Hope anyone can help me and thank you in advance,
chelin
chelin
