I have a couple of questions regarding arc flash study as below:
1. In arc flash study when we assume that the main breaker of the MCC is isolated from the bus by a barrier, then should we print two labels for the MCC (first label for the cubicle which contains the main breaker, and the second label for all other cubicles of the MCC)?
2. When we perform coordination of phase breakers as part of arc flash study, the settings of phase breakers change which affects the incident energy. Will the coordination of ground breakers also affect the incident energy? In other words, is ground coordination also required as part of arc flash study?
Thanks.
Thanks.
