Sojournerman
Industrial
- Jun 5, 2014
- 29
Arc length seems to be a problem for me done the youtube thing and the google thing as well all good info but it doesn't give me the right answer tried all sorts of things.
So 1 3d sketch(sweep) 2 arcs on the 3d sketch right next to each other not much different in size .
One says 98ish mm the other says 631ish mm the 98 one is im sure right but the other 631 is to the outside of the arc not the bit I want measured.
also I cannot get the dimension arrows/leaders to display the way I want either.
small screen capture attached
Thanks for the help and advice
sw 2006 5.1
Picture file link
sw 2006 5.1
Picture file link
