hi guys,
it has been reported to me that on a distribution transformer (750KVA , 13.7 Kv) an arcing had caused the definitive damage of the transformer.
i was wondering if some of you already experienced this kind of problem , and if the caps on the unsused HV inlets are sufficent in term of insulation , as this transformer is in a tropical country (Haïti to be precise).
the local electrical engineer is only focused on a sabotage , because of the hole in the cap , he seem to ignore the effect of high voltage on thin insulation
so i would like to have you opinion on that problem , who seems to me to be a insulation defect of the inlet connector and maybe a cap not appropriate for securing the unused inlets.
thanks in advance
best regards
Jean Michel
thanks in advance
best regards
Jean Michel
