KootK
- Oct 16, 2001
- 18,554
In a perfect world, I would like it if no building ever drifted (seismic or wind) beyond it's bounding property lines. That would keep things simple. So long as future buildings followed the same requirement, we'd have no issues with pounding etc.
I have, however, worked on numerous, neighbor-less buildings where the edge of structure was literally right at the property line. That obviously implies that these buildings would drift over their property lines under wind and seismic actions.
So my questions are:
1) Should building drift be limited such that buildings do no cross their bounding property lines under wind and seismic?
2) Do we typically assume that existing, neighboring buildings have been designed not to cross the property line under wind/seismic? Typically, I have not.
3) Do we typically assume that future, neighboring buildings will be designed not to cross the property line under wind/seismic? Typically, I have not. Rather, I have assumed that future building designers would have to estimate the drift in my building and deal with it regardless of the property line location. I haven't liked this assumption.
4) When considering the pounding of neighboring buildings, you're allowed to pull the SRSS statistical voodoo to minimize the required gap. How would one adapt that provision to a case where the goal is not avoiding contact with an adjacent, mobile structure but, rather, contact with a stationary, vertical plane?
Yes, it is shameful that I've gotten this far without ever having resolved these issues.
