StructureMan44
Sometimes I have seen concrete note drawings specifically list the required concrete mix details. Is this necessary or is specifying ACI 318 (mainly chapter 3-Materials) sufficient?
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
I think it depends on the type of job. The only time I specify a concrete mix is when I do exterior suspended slabs and I get that mix from a concrete consultant friend of mine.. Most of my other work is only light commercial and residential footings and interior slabs. I typically just specify the compressive strength and am done with it. Same as my competitors - so I meet the local standard of care. If I was doing R/C buildings, it would be a different story. I don't pretend to be a concrete expert and I can actually see getting in more trouble by over or incorrectly specifying it.Ron said:A structural engineer MUST know the materials upon which his/her design is based. To specify a 3000 psi concrete and give no further direction or limitation is irresponsible, does not meet the standard of care and leaves the engineer open to a variety of claims.
XR250 said:If I was doing R/C buildings, it would be a different story.
XR250 said:I don't pretend to be a concrete expert and I can actually see getting in more trouble by over or incorrectly specifying it.
BigH said:What gripes me, though, is when a spec says to use a w/c ratio of such and such and a requirement on strength but also gives a minimum cement content.
Macgruber22 said:Those comments seem to conflict - Or are you saying that you would learn more concrete mix design if you were designing framed concrete buildings?
