KirbyWan
Aerospace
- Apr 18, 2008
- 586
We use Aluminum Oxide to abrasive blast magnesium parts. Someone said magnesium dust is a fire hazard and we should not do this because it's dangerous. I did a search and could find very little about fire or explosion danger to magnesium in this context. I know magnesium can burn and the powder can be explosive, but it's generally difficult to ignite, so using a cutoff wheel or high speed grinding might be dangerous, but not abrasive blasting as far as I know. Note, I have seen high powered abrasive blasting that shoots sparks off of steel, but I'm working to P&W SPOP 218 in this instance and it has limits on the pressure of this system.
I'm going to use the Pratt and Whitney process as justification of the acceptability of our process, but to be overly cautions, I thought I would put the concerns here to see if someone has the knowledge to verify or falsify my opinion. Has anyone seen a magnesium fire caused by abrasive blasting? Are there other specific limits that should be followed to ensure safety?
-Kirby
Kirby Wilkerson
Remember, first define the problem, then solve it.
-Kirby
Kirby Wilkerson
