Array in assemblies
arun17
44
Hi!
Could somebody tell me if one can create an array of the inserted parts in a assembly with the mates applied to that part?
Regards "Knowledge is power"
Yes, while in your Assy, select Insert>Component Pattern. From there you select the parts you want to copy, set the spacing between them (or use predefined holes) and away you go. "Happy the Hare at morning for she is ignorant to the Hunter's waking thoughts."
In addition to the answer gaven by madmango:
Perhaps you could create a mirrored component, in the field: "Insert, Mirroreds Components". Then, try to reconstruct it with the option "Recreate Mates". This would create a copyied component, not a mirrored component.
My best regards.
