Array index of maximum value
REBJ
Aerospace
I have an array of values. I can use the max function, ie. max(array), to output the maximum value in the array. However, I would also like it to output the array index value at the maximum. It's easy to do by graphin it and using the trace function or such, but I wanted the program to find it on its own. Does anyone know of a way to do this?
Is there some reason you can't use the match function?
TTFN
I know nothing about the "match function". So I can't say it won't work.
Then you should look in the help file
TTFN
Thanks alot. That works just fine. Just didn't know about the function.
