Array problems in journal 1
cowski
8,202
I'm updating an old grip program I have (see thread561-52509) to a journal to add some new features. I'm having trouble passing arrays into/out of a couple of functions; I get an error message "Number of indices is less than the number of dimensions of the indexed array". A quick google search gives some info but I can't seem to get the 'suggested fix' to work.
Any ideas?
When declaring array lengths in vb always declare as required length-1. e.g., bbox(5) for a 6 element array.
Also when passing the array to a function pass it as bbox, not as bbox().
I have modified your file. You can see what I have done.
Suresh
www.technisites.com.au
 http://files.engineering.com/getfile.aspx?folder=02474b67-fc34-44d7-9855-944febc54fa3&file=bbox.vb
Thanks again, Suresh!
I had tried several different ways to declare the arrays, but my real problem was with how I was calling the function.
