In article 310.15(4(a) regarding the Neutral Conductor, we have differences of opinions on what it says. The article says "A neutral conductor that carries only the unbalanced current from other conductors of the same circuit shal not be required to be counted when applying the provisions of 310.15(B)(2)(a)."
If you have (3) hots A, B,and C phase and (3) neutrals (one for each leg) are you required to count the neutrals when applying the provisions of 310.15(B)(2)(a)?
We have one guy that says that this is only used whe you have a multi pole circuit (i.e. 2 or 3 pole) that also requres a nuetral. Tell me what you think.
