  • Congratulations IFRs on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Articulation under Advanced Simulation
TimT27
8
Hi All,
I'm trying to use the "articulation" simulation object type while doing some thermal-flow simulation. However for some reason I have to apply it when the "solution" is inactive and then when I activate the solution again after implementing the articulation, the articulation object doesn't activate which obviously means it won't do anything in the simulation.
I think I must be missing something here but how do I got about using articulation and actually activating it when simulating? I'm trying to do some thermal analysis of a braking system and I want the rotation of the wheel to be included for the flow analysis.
Dear Tim,
Take care when defining the analysis in NX Flow/Thermal, you must select the SOLVER, for instance NX Thermal/Flow, then the ANALYSIS TYPE = Thermal, and finally the SOLUTION TYPE = Advanced Thermal. This last point is critical, if you select THERMAL instead ADVANCED THERMAL then the command SOLID MOTION EFFECTS is not active in your menus, because ARTICULATION is part of ADVANCED THERMAL only, OK?.
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48011 BILBAO (SPAIN)
WEB: Blog de FEMAP & NX Nastran:
Hi Blas,
Thank you very much for the reply. If the "Advanced" solution type is not available (see attached screenshot) does this just mean my licensing isn't up to scratch and I need something more? I'm using NX7.5 if that makes any difference...
Kind regards
Tim
Dear Tim,
SOLID MOTION EFFECTS (ie, ARTICULATION) is a feature available only with the licenses of NX ADVANCED THERMAL, NX ADVANCED THERMAL-FLOW, the COMPLETE solution, NX Space Systems Thermal (SST) and ADVANCED-NX Electronic Systems Cooling (ESC).
Best regards,
Blas.
Blas Molero Hidalgo
Director
IBERISA
OK. Thank you very much for your help
