AS1170.2 2011 Parapet Reduction Factor
JimLeip
1
I noticed that the parapet reduction factor in AS1170.2:2011 doesn't allow reduction for the RC1 case with local pressure factor (KL) of 3.0.
I am designing a sturcture with a large parapet that reduces the RA1 and RA2 cases by 0.5, but figure I can't reduce the corner local pressure factor from 3.0 at all!?
Surely there has been an oversight from the previous AS1170.2:2002 and a large corner parapet could reduce the local pressure factors at the corner?
I would assume an oversight and apply it to RC1 also.
assuming the parapet returns around the corner, it would also apply. if not then I think not.
How could you do anything so vicious? It was easy my dear, don't forget I spent two years as a building contractor. - Priscilla Presley & Ricardo Montalban
