AS3600 - Flexural Crack Width Limit
structuree
AU
In the 2018 code, AS3600 poses limits on bar stresses based on limiting your crack width to either 0.2, 0.3 or 0.4mm. Forgive my naivety, but... How much of a difference does 0.1mm difference in crack width really make? Does it make enough of a difference to limit the bar stress by (for example) half to save a few 0.1mm crack width?
I can only really understand if there was concern over waterproofing. Crack widths would ideally be non-existent. But I guess that brings me back to the question - 0.1mm is such a small increment.
It's also +50% and +100%. But you have to take account of the consequences as you say. Indoors, air conditioned, invisible between carpet and ceiling tiles = WGAF. Environment that promotes corrosion is another matter.
Architectural concrete is another circumstance where easily visible cracks are a design failure.
0.2, 0.3 and 0.4mm cracks all look different. A 0.4mm crack is a lot more noticeable than a 0.2mm crack. A 0.2mm crack also provides better protection from wet/corrosive environments than 0.4mm crack.
 I
