Illbay
- May 22, 2001
- 54
I'm trying to design a structural frame for a piece of vibrating equipment. This is the first time that I've encountered dynamic loading outside of seismic (which has its own very well-defined and quite elaborate rules) that potentially govern the design, and it's not clear how to handle it. I note that the very first entry in the list of loads in ASCE 7-16 Section 2.2 is "A-sub-k" which is defined as "load or effect arising from extraordinary even A", which would seem to suit my purpose exactly. Except there is no load combination where "A-sub-k" appears in either section 2.3 or 2.4. The commentary is utterly silent on the subject. So how do you properly account for this load effect in combination with others?
"No one is completely useless. He can always serve as a bad example." --My Dad ca. 1975
