CivilSigma
Section 7.4.1.3.1 asks you to calculate the seismic base shear using factors C1C2.
C1C2 can be found in table 7-3, but this table requires the value of m_max.
M_max by definition of the code is the largest m-factor for all primary elements of the building in the direction under consideration.
But, ASCE7-41 does not elaborate any further.
How do you calculate the m-factor? What is the m-factor?
