19750412
- Feb 23, 2007
- 17
Hi All.
Before i get a questions, small introduction to subject. Now I’m working in some project of main steam pipelines which are designed and manufactured according to European standard EN 13480. Due to fact that this standard dose not allow to design straight tees in creep range my subcontractor used to design of them ASME B31.1, what is allowed in EN 13480. The materials used to construction of complete pipelines fulfill requirements of adequate European material standards for different products as pipes and forgings and it is X10CrMoVNb9-1 what is comparable with ASME SA 182 F91 for forgings, (material for tee). The strength calculations according to ASME B31.1 has been proceeded based on ASME material to fulfill requirements of standard.
And now i have two questions.
1. Dose red marked area on attached sketch can be considered as reinforcement area A4 as is defined in point G.6.3 or on sketch (c) in fig. 104.3.1(G)?
2. Is it allowed to use such designed tee for pipeline which must work 200 000 h, as required EN 13480, having on mind that ASME give allowable stresses in creep range based on lifetime 100 000 h.
Thanks for help.
Arti
Thanks for help.
Arti
