HgTX
- Aug 3, 2004
- 3,722
As I read QW-452.3, ANY pipe over NPS 2-1/2 qualifies for diameter down to NPS 2-1/2.
Which means, in theory, someone could weld pipe with 6 ft diameter and qualify to weld 3" diameter. They'd be a long time welding, but it looks like it would be legal.
At what point does pipe become plate? Plate tests qualify pipe over 24", but have limited application for pipe under 24". But there appears to be no restriction on how big that qualification pipe can be, and no connection of qualified range back to actual diameter welded as long as it's over NPS 2-1/2. If pipe welding truly takes a different skill from plate welding, shouldn't there be a max diameter based on something other than the practicality of how long they can afford to spend welding the sample?
Am I missing something?
Hg
Hg
