I am performing an elastic-plastic simulation on a vessel. I've correctly generated the elastic plastic stress strain curve but I'm lost on the calculation of the proportional limit. I read the comments by TGS4 on the parent topic, but I'm still confused with the iterative procedure for the proportional limit? There's the arbitrary true plastic strain to be taken as 10^-6. Is it simply based off true strain(total) = True Elastic strain. I feel that I am overthinking the process after being muddled up in the definitions.
File attached for reference.
Thank you.
Thank you.
