ASME code section II Part A Ordering Information
wcw1985
44
Dear Forum member,
I have 1 queries about the ordering information as per asme II
when i order a pipe (SA 106 Gr.B)
Under ASME II Part A (3.1.12) End Use of material.
Does this clause means that i have to state the reason i buy the pipe in my ordering information?
Thanks in advance for reply.
wcw
No, not the reason only if it will be used as pipe or some other final use.
Dear metengr,
Do you mean that i have to tell my supplier the use of the pipe after i purchase it?
Example of my material requisition form:
PIPE DN300 SCH40 X 550MM (SEAMLESS )
SPEC: SA106 GR.B
ACCEPTABLE ASTM ED: A106 GRB 88a THROUGH 08
HOT FINISHED
O.D AND I.D VARIANCE < 1%
HYDROSTATIC TEST ACCORDING WITH SPECIFICATION
A530/530M OR 13.3 OF MENTIONED SPECIFICATION.
END USE OF MATERIAL: SHELL
Do i order the material according to asme code?
No one uses it even if the spec calls for it. On p.o. you can mention for pressure vessel use. It will only help you. Mention the ASME Code year and addendum.that will clear the ASTM acceptance requirement.
