TECHNICAL NOTE:
REVIEW PP25+PVRC+PRESENSTATION BY John Ludman, Randy Wacker, Kevin Kelleher, and Ed Perez May 24, 2005.
Optimizing Torque Values:
Why we did the work
How we did the work
What we learned
what needs to happen
Why optimize?
Existing Corporate Flange Assembly Standard based on single bolt stress value for “sheet” (20 ksi) and spiral wound (45 ksi) gasket
Poor sealing experience
Some flanges damaged (rotated)
Previous PVRC efforts shows need
W.E. Short - ASME PVP-Vol. 235 1992 - referenced PVRC initiative to study stress limits of 16.5 flanges (FEA)
Rodabaugh/Moore - ORNL-NRC-5 - a) ASME rules don’t adequately analyze ASNI flanges, need for limit analysis
Several sources of conflicting torque tables
Sources of Recommended Pre-load
Gasket Manufactures - consider gasket stress and bolting
PCC-1 - Similar to existing corporate standard, single bolt stress value (50 ksi)
ASME Flange Calculations (Appendix 2) - max allowable pre-loads were conservatively low (Rodabaugh/Moore Study-suggests 40 ksi bolt loads although ASME rules predict excessive stresses)
Pre-load required to achieve “tight” (T3) seal - only considers gasket, not optimal
Rule of Thumb - 40% of bolt yield strength (Bickford)
Optimal Pre-Load
Maximum pre-load that does not damage fastener, gasket or flange
Flange - consider stress and deflection (output only)
Gasket - consider mechanical properties
Fastener - assume high strength bolting only
“Tightness” is an output not an input
Conditions of Analysis
1) ASME B16.5 Flanges (Lap Joint, Weld Necks)
2) Design Conditions, pressure rating at 400 degrees F.
3) Diameters, 1/2” through 24”
4) Standard Pipe Sizes
5) Material A105
6) High Strength Bolting
7) Spiral Wound and Sheet gaskets (allowable compressive stress > 10,000 psi)
General Strategy
1) Established acceptable limits of stress (flange, bolt, gasket)
2) Adjusted fastener loadings to achieve flange stress limits
3) Compared resulting gasket stress to gasket stress requirements (T3 seal, manufacturer’s recommendations)
Lap Joint Flanges
Method
ASME, Division 1 Appendix 2 equations
Limits and Considerations
1) Bolt-up case only (pressure increases stress by ~ 12%)
2) Flange stress limited to 90% of hot yield (at bolt- up)
3) “Hub” not included in Appendix 2 calculations
Verification
1) Axisymetric Finite Element Modeling (considered hub)
2) Verified several sizes (proved method used was conservative)
Weld Neck Flanges
1) Limit Flange stress to 90% Sy
2) Limit Hub stress to 1.7 x Sy
3) Yield (Sy) value at temperature
Verification
1) Elastic-plastic FEA analysis (for hub stress)
2) Verified bending stress in hub was “secondary”, use criteria of <2 Sy
Method
1) 3D Finite Element Modeling (AxiPRO, Paulin Research)
2) Gasket dimensions per ASME B16.20 (spiral wound) and ASME B16.21 (ring)
3) Reviewed output (flange stress and deflection) and adjust bolt load to approach limits
I could not add the rest of the pp.
E.C. Rodabaugh and S.E. Moore published a report “Evaluation of the Bolting and Flanges of ANSI B16.5 Flanged Joints ASME Part A Design Rules” sponsored by US Nuclear Regulatory Commission, We were referred to this report by Clyde Neeley. Available through National Technical Information Services (ORNLSUB29133)
This PP is available.
