DK44
- Sep 20, 2017
- 196
Are ASME GMGC gaskets and Kammprofile (KAM) gaskets are different.
I observed that ASME GMGC (understood to be Grooved metal Graphite covered) is listed in the code with m=4.25 and y=10100 psi (70 Mpa) where as Kammprofile gaskets are Low Stress(LS)gaskets as propagated by the suppliers with m=2 and y=17.2 Mpa. Accordingly the Seating load of ASME GMGC will be much higher(about 4 times?)than KAM. Hence KAM offers optimum Flange & Bolt design
1.What makes KAM Gaskets to offer low m&y
2.What are the construction differences between the two.
3.When designed with KAM gaskets with less bolting Torque, the supplied gaskets resembling KAM will act like GMGC demanding more Bolting Torque.
4. How to differentiate between the two.
