EMANUELE GUERRINI
Industrial
Hi everyone,
I'm working in an Italian workshop certified under ASME Section I (Stamp S), and I need to build a boiler with a capacity of 1500 kg/h and an operating pressure of 0.98 barg (15 PSI). Since the pressure falls under the scope of ASME Section IV, I wanted to ask the following:
Can I use a safety valve certified under ASME Section IV, or does it absolutely have to be an ASME I valve, even though the pressure is low? I'm concerned about the long lead times and higher costs associated with ASME I valves.
Additionally, can I ship the safety valve separately from the boiler and have it installed later, as long as the valve meets the necessary certification requirements?
Any insights or guidance would be much appreciated! Thanks in advance.
