Hi all,
In ASME I 2004 PG-72.1, it's written that "After blowing down, all valves set at pressures of 375 psi (2.7 MPa) or greater shall close at a pressure not lower than 96% of their set pressure, except that all drum valves installed on a single boiler may be set to reseat at a pressure not lower than 96% of the set pressure of the lowest set drum valve."
However, in ASME I 2007 of the same paragraph, the reseat pressure of 96% below set pressure requirement is not there anymore.
1. What are the possible reasons that this requirement is removed?
2. What is the minimum difference (good engineering practice or code requirement?) between maximum operating pressure and PSV reseat pressure for drum?
Thanks in advance for your help!
