Hi All,
In API 1104, we need to record down all the time lapse between passes from root, hot , fill until cap. However for ASME IX does not mention about that.
Now my problem is if I finish the welding of root, hot and one layer of fill passes then I stop welding and let the weld bead completely cooled, after 3 days I just continue welding again until cap. Is that any problems in term of mechanical properties of materials and also the the defect that I gonna face since I let the weld cool down after complete the hot pass?
Besides , is API 1104 and ASME IX allow us to do that? If not what is the theory behind this?
Thank you
Thank you
