Hello one and all,
I have a question regarding the ASME IX code. A procedure is qualified by welding a 6" Sch 80 pipe, wall thickness 0.432" (10.97mm). As the procedure will be used for a pressure application, notch toughness testing is required. QW 403.6 applies in this instance and limits the thickness range for a pressure application to T - 2T, (0.432" - 0.864")
Years later, a welder welds a single test coupon using the same weld procedure but with a 4" Sch XS pipe, wall thickness 0.337" (8.56mm). It is subjected to Volumetric NDE only to qualify it.
Does this additional 4" test coupon need notch toughness testing to allow it to be used in pressure applications, or does the earlier notch toughness testing on the 6" pipe qualify it?
Thanks if you can help,
DeanIEng
DeanIEng
