hello every body
I have a problem with my owner.
there is a 50 MM thick disk, which is a pressure boundary component (pressure part), which is subjected to 52 bar test pressure, the temp. is 250 c, and the fluid is NH3+H2S+H20+CO2, the material of the disk was selected AISI 304, for some reason we want to use AISI 301 in lieu of AISI 304. but the owner said that this material in this temperature and pressure can not use instead of AISI 304, and it is not an ASME material for pressure parts.
question 1:
where i can find ASME materials in sec8?
question 2:
the strength of 301 is 33% better than 304 for our work. but the owner focus on the corrosion problem in this press and temp. is there any justification to satisfy the owner?
question 1:
question 2:
