ASME Pressure tank as a vacuum receivers?
Joseph_L
CA
I am looking for a vacuum receiver tanks, and I could not find many.
I read some online forums about ASME pressure tank code, and they do talk about external pressure stability. Can I use an ASME pressure tank as a vacuum receiver tank?
The tank is subject to go through cyclic load of vacuuming and partial purging probably 5 times a minute.
Thank you in advance :)
Full vacuum is only 15psi. Assuming you're not talking about quite large tanks, should be fine.
You can use it providing that the name plate says full vacuum as the min pressure.
Many even high pressure vessels don't like negative pressure.
But some size and pressure rating of the vessel would be good to know.
e.g. see this for info noting that you might need thicker shell / heads for vacuum than pressure if the pressure is relatively low.
I think if you're talking MAWP of >50 bar you're probably Ok, but the devil is in the detail.
If designed for high pressure the tank may be OK. But even then you need to check for external pressure suitability to be on the safe side. Also since the pressure is variable, the fatigue criteria need also be checked.
Engineers, think what we have done to the environment !
Thank you all for your feedbacks.
Many ASME compressed air tank tells about its maximum pressure rating without min pressure rating.
For example, McMaster Carr is selling an ASME code pressure tank, which does not talk much about its min pressure. I think there is no way that I con contact the seller/manufacturer of this tank and ask this question about the min pressure... right?
I was looking at 60 gallon tank:
Quick FEA seems okay with 1/8" wall thickness .. but this is overly simplified model.
Joseph_L, if you are thinking of buying an off-the-shelf tank, I think the cyclic service is going to be a deal breaker.
Mike
If there is external pressure, it must be stated on the nameplate. Nothing listed means it hasn't been designed for what you call "min pressure".
I highly doubt 1/8" will meet FV....add cyclic and as Mike stated...a deal breaker.
Well at the end of the day, if the tank fails in vacuum then it collapse or leak and little harm comes to anyone standing next to it. you suddenly lose vacuum which might cause an issue, but we don't know.
HOWEVER, if you use it this way and it fatigues a lit then someone decides to use it as a compressed air tank again then that's a potential rupture right there.
If there is no specific vacuum designation then it is not designed / certified for it.
5 time a minute for how many minutes / cycles?
I can't see a 1/8" steel tank designed for internal pressure lasting very long if this is 10 hours a day for weeks on end.
The FEA analysis you have done (presumably with external pressure) does not indicate any deflections. Usually FEA software do not have the facility for checking the elastic stabilities under external pressure or compressive loads. So you may get a stress lower than yield stress but the vessel may be elastically unstable and hence buckle. This needs to be checked according to Sec VIII-1.
Well a little search found this
Now the price seems to be about 4 - 6 times more than your air receiver. This tells me there is a big difference between an air receiver and a vacuum when it is properly designed.
You pays your money you take your chances....
Thank you for all feedbacks.
Cyclic loading is indeed a challenge.
Custom making one will be quite expensive... so I was hoping to find an off-the-shelf item.
This tank is never subject to a pressure higher than atm for its entire lifetime.
This tank is subject to be under cyclic loading 5 times a minute - continuous duty (24 hours).
From the quick FEA with 1/8" wall, max stress is 24 Mpa (3.48 ksi).
General fatigue strength is 40% of ultimate tensile strength.
Roughly 170 MPa (24 ksi) for steel from my research.
The stress seems to be well under its fatigue strength... would it still be a deal breaker?
@goutam_freelance, oh. I should re-calculate the stress.
What eccentricity did you apply? Have you checked buckling criteria?
What will happen with the light one is that it will start to distort around joints and fittings, and then the local loads will change, and then the loads will become less uniform. A simple dent or ding in the side could lead to collapse.
Pay 5x and get one rated full vac.
Thank you all for helping me out.
@goutam_freelance
I will definitely check out ASME Sec VIII Dev i claus for this.
@EdStainless
Would a tank rated for full vacuum withstand the cyclic loading then?
Problem is that I would much prefer to buy a stainless steel tank; then the price would be 7~8 times. If I have to, I will do. I do not want to take a chance in any cases.
Don't take the chance. If you buy an expensive SS non-rated tank then fail it you will look very foolish.
What grade of SS are you looking for?
I am looking for 304L or 316L stainless steel.
This tank will be placed in a food processing facility.
I was also considering steel tank with powder coating outside and epoxy lined inside to lower the budget too.
I have contacted McMaster-Carr about the manufacturer of some items and they have passed that information along to me; often the manufacturer won't do a direct on-piece sale, so McMaster-Carr does not lose out.
I am curious as to how the tank will be evacuated and refilled so rapidly. The pressure swing isn't much different than pressure vessel use, so there is that, but I also note that, for example, a soda bottle can see 150psi with no problem but cannot withstand more than 1 psi vacuum. See what happens if there is a flat or dent in the long side of the FEA model to be sure it's stable. (I now see that Ed had a similar observation.)
I am puzzling over the temperature cycle - it seems to me that there will be more cooling than heating, allowing condensation on the humid side (inside and or outside.)
This vacuum receiver tank is used as a vacuum reservoir.
It will be constantly connected to a vacuum pump.
This tank will be used to pull a vacuum from a smaller container rapidly.
So, the ports to those smaller container will be open and close, which would cause the fluctuation of vacuum level.
Did you miss my post? Vacuum receivers are a ready supplied thing but are more expensive. This will be for a good reason.
Search vacuum receivers and stop trying to nickel and dime this.
@LittleInch, thank you.
I've been contacting many vacuum receiver manufacture.
Appreciated your feedback :)
