ASME SEC IX # WPS/PQR
Sajith013
3
Dear All,
Please help me to sort out below observation
i have a wps/pqr for A 106 GR B without impact test.
Welding Process : GTAW+ FCAW
GTAW : ER 70S6
FCAW : E 71T -1C
Is that possible to use the same wps to weld ASTM A 333 Gr. 6 material & kindly check the above electrodes comply to weld A 333 gr 6.
david339933.
Yes, but it will not give you the lower temp of A333 Gr.6.
Actual job grade is ASTM A 333 GR 6. ONLY...
I just wanted to know whether i can use the above mentioned WPS.
& the electrodes mentioned above can be used in ASTM A 333 GR 6.
Sure. My point is that A333 Gr. 6 is low temp pipe which is impact tested to -50F. You can't expect the filler metals to meet this without testing.
If you don't want impacts, then yes, this procedure is good. Both materials A-106B and A-333 are P1 materials.
david339933
Sir,
Noted. Tank you for the support.
David's point is that once you weld it with that filler you will not have Gr. 6 any longer.
It depends on the MDMT of the pipe system and the applicable Code.
