ASME Section 8 DIV 1 13-10 Obround Design
I am trying to design an obround nozzle for a heater treater, so I'll also need to understand the weld to the head, the weld to the vessel flange, sizing the vessel flange, the blind flange, and sizing the blind flange. If anyone has any literature, I'd appreciate it. I know you can run FEA as well and use some DIV II stuff, but my first go at it is kinda rough. A step by step would be cool. I have the use of Compress 8200 as well, but it doesn't really understand obround nozzles directly (maybe there is some manipulation).
Refer to 13-4(c).
I don't think you need to use Div-2 for this kind of design.
I know in Canada they accept obround flange designs for VIII-1 vessels using the BS 5500 methodology, as it falls under U-2(g).
swiftworks, obround and other non-circular shaped flanges may be designed (preferably as loose flanges) per Apx 2 methods paying attention to proper uses of area and perimeter. Not familiar with BS5500, no opinion there.
IdanPV has pointed out the way for your original query, has to do with tensile and compressive stresses. Weld sizing is addressed in Part UW. A blind may be designed per UG-34.
This is a complicated design you are undertaking. A comprehensive understanding of Sec VIII, Div 1 is needed. There is no step-by-step. Some mentoring by your organization is essiential.
Mike
