Table UW-12 lists the Weld Type associated with Joint Description and Limitations.
The limitations for Type 3 ( Single welded butt without backing strip)are: Circumferential butt joints only, not over 5/8 " thick and not over 24 in. OD.
Does this mean that the code does not allow a vessel design with circumferential butt joint (of Category A,B or C)that is over 5/8 " thick and over 24 in. OD ?
