aregularengineer
For a certain project, we are using a 20" SA-333-GR6 seamless pipe as the shell with SA-420-WPL6 seamless cap fittings. There is no radiography for this vessel.
According to here (assuming the information here is correct) , shouldn't the joint efficiencies be 0.85 for category A longitudinal welds and 0.7 for category B circumferential welds?
My boss is convinced that it should be 1.0 for the category B circumferential welds and he's convinced that the information in is for plate shells only, and that a different set of joint efficiencies apply for pipe vessels. But I don't see that indicated anywhere, and it should apply to seamless pipe since it is my understanding that you cannot have a seamless plate vessel (it has to be rolled and welded), or else why would it indicate "seamless"?
Any answers would be appreciated.
