ASME VIII-1 welding for internal projection nozzle on standard blind flange 3
FPPE
194
I have a question about the calculation in accordance with ASME VIII-1 for the configuration shown below:
what are the reference paragraphs for the calculation of the standard blind flange with a 4" nozzle inserted as shown in the detail? Being a standard component but modified due to the presence of a hole, it needs to be verified in accordance with the code. Could it be calculated as a slip-on, considering the 4" pipe as if it were the shell of the flange?
Thanks in advance
Solution
"Question 3: An ASME B16.5 reducing flange requiring a hub has an axial hole in the center that exceeds the size limits in UG-36(c)(3). Is it acceptable for Section VIII, Division 1 construction to use the ASME B16.5 pressure-temperature ratings for this flange without performing the reinforcement calculation per UG-39?
Reply 3: Yes"
I understand that in my case (12" blind with a 4" nozzle), I could use (referring to Table 6 of ASME B16.5) a reducing flange with the dimensions of a 12" blind, plus the hub of a 4" WN welded to above pipe. Considering that the 4" pipe has a thickness of 13.49 mm, the internal diameter of the blind would be (114.3 - 2*13.49) 87.32 mm.
In this case, no calculation would be required according to...
Reply 3: Yes"
In this case, no calculation would be required according to ASME VIII-1, and we can simply follow the pressure-temperature rating of B16.5.
Is my interpretation correct?
I think that your interpretation is correct.
I suggest you to ask your A.I.
Note that some provinces and jurisdiction sometimes don't accept the use of Interpretations.
As for the weld design - I think the UW-16.1(i) or (l) might be suitable for you case, pay attention to the symbols and notes.
Solution
Hi RadiateurFou,
The image is a screenshot of the existing equipment drawing not designed by us.
We now need to redesign it completely.
Thank you very much IdanPV!
@FPPE,
I've found some old threads from this forum that might help you:
The last one seems to be very helpful
To further add to that, I have found the following similar threads to be very valuable in the past
I think there's one more that I cant find right now, Ill post it if I find it
Thank you XL83NL, very useful!
