wdavidchris
Apologies is this has been asked before or is a silly question. For ASME VIII Div.1 for Hydrostatic Test, from UG99(b), it says the HT should be at MAWP X 1.3 X LSR. We have a tank with a specification of A240 304/304L material (dual-specification). The design / MAWP temperature for this vessel is 250 deg Celcius.
The S (from ASME II Part D) for A240 304 is 138 MPa and 89.9 MPa (at test & design temp 250); S for A240 304L is 115 MPA and 103 MPa (at test & design temp 250. So, the LSR for 304 grade is 1.54 (138/89.9), LSR for 304L grade is 1.12 (115/103).
So, my question, which LSR is supposed to be used for the Hydrotest; 1.54 or 1.12?
Choose the conservative 1.54 to be safe?
