APIPapi
Chemical
- Jul 17, 2023
- 11
In the past, I have always utilized a static head factor of 0.433 ps/ft and vessel MAWP to determine my component tmins for our Sect VIII div 1 vessels. However, the process fluid used has a higher SG than water. Shouldn't I use a head factor based off the SG of the process fluid rather than water? I have never seen this done by any inspector before, and I don't see this mentioned in API 510. UG-21 of sect VIII div 1 states to use the "coincident static head", but like I said, I have not seen any inspector use a different static head other than water for pressure vessel calcs.
